Post your 4X4 pictures HERE!!
Re: Post your 4X4 pictures HERE!!
Thanks Manny, those are 235/85 16's......
1971 F250 Explorer 4wd
2006 E350 Adventure Van 4wd
- Manny
Dig it alot.Socal F250 wrote:Thanks Manny, those are 235/85 16's......
Looks great as is. Love the simplicity of the exterior, but I find it irresistible to be the model for some modification project.70short4x4 wrote:Thanks guys. I brought the rear up just a tad. The nose high look (even though it was totally level) wasn't doing it for me. Looked too squatty in the rear with the lowered wheel well openings.
I'm much happier with how it sits now. New trucks look good level. But I think these old trucks need a little bit of rake to em
- 67mann
makes me wish my project truck was a "High Boy"....nice stance and patina
Thanks 67!! Having a great time with her.....
I see you found the wheels you were looking for-much betterSocal F250 wrote:
Kyle
Kyle
Yes & Thanks Lone Ranger, they work perfect for the look I wanted.......
My best friend...
Rebuilt everything that can be rebuilt.
Many Mod's,... biggest being adding the Advanced Adapter's 2 speed gearbox in front of the NP-435.
That thing is sweet! Is it sitting on 35s? I've been throwing around the idea of bigger tires.Lee wrote:Truck_resized.jpgOwned her 17 years.
What's the two speed gearbox? A spliter?
Kyle
Kyle
Thanks!!!!Lone Ranger wrote:That thing is sweet! Is it sitting on 35s? I've been throwing around the idea of bigger tires.Lee wrote:Truck_resized.jpgOwned her 17 years.
Yes they are 35" s....If I turn to far to the right they do scrub alittle.
The AA gear box is like a Splitter. The 2 speeds are 1:1 (Direct) and 27% overdrive. So,... now I have 8 forward gears and 2 reverse gears. I call them "Half" gears. The advantage is that I tow a heavy trail trailer over a steep mountain pass here in WA state. I can't maintain speed in 4th gear and there is such a wide gear ratio spread between 3-4th that downshifting to 3rd has the RPM's wa'aaay up there. Now I downshift to 3 1/2 gear
Also, when running empty on the highway I use 4 1/2 for better cruising.
You have to move the NP-435 back 7 1/2 inches, shorten the intermediate shaft, relocate the 435 cross member, relocate the location of the 435 and transfer case shifters, etc... like I said it's a big project.
- Manny
That thing is awesome. How much lift is underneath it for those 35's. Truck looks great.Lee wrote:Yes they are 35" s....
Additional 3" body lift.Manny wrote:That thing is awesome. How much lift is underneath it for those 35's. Truck looks great.Lee wrote:Yes they are 35" s....
- Manny
Thanks always trying to figure out how they are built. Means I may stick with 33's... decisions decisionsLee wrote:
