stock metal inside door panel years?
zakt
Post by zakt »
Did 1972 have the stock metal inside door panels. What years did have those?? I know my 67 did but thinking the handles for the 67 are different then the 69-72 so probably wouldnt work without some major mods (cutting/welding)
Todd
1972 Ford F350 crewcab
71 LONG BED
Re: stock metal inside door panel years?
Post by 71 LONG BED »
You need metal door panels? I have a set, with clips and screws, that will fit a '72.
John Member #1549
Image Image Image
zakt
Post by zakt »
have any pics of them??
Todd
71 LONG BED
Not handy, but I can get some this weekend. They are in my shed at the moment, or I'd do it now. :P
John Member #1549
Image Image Image
i think 71 was the last year to have the metal ones. but i could be wrong. i havent seen a plain jane 72 so those might have had the metal instead of the fiberboard panels.
TheEskimo
Post by TheEskimo »
My '72 has the metal ones, so I think they could be had in all the Bumps if '67 had them as well.
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
67 had them too. but the 67 panels are different than the 68-72 panels.
Quick69
Post by Quick69 »
can you make 67's work???
I am looking at a 67 f600 that has the metal ones
1971 F100 Ranger XLT
302/C4/3.25
3/4 homemade drop
the holes fo rthe 67 panels are all in a different place. so even if you cut new holes you will have the old holes still in the panels.
flyboy71
Post by flyboy71 »
fordman wrote:i think 71 was the last year to have the metal ones. but i could be wrong. i havent seen a plain jane 72 so those might have had the metal instead of the fiberboard panels.
I have a metal set that came from my Dads mallard green 72 and I have a black vinyl fiberboard backed set from my 72 Explorer special. Metal panels are screwed on and the vinyl fiberboard panels use clips. Thats all I have to say about that. :D :2cents:
-Jeff
