1967 F-100 project
67nukeford
Re: 1967 F-100 project
Post by 67nukeford »
Dropped the cab back down, and installed the front clip back on. Engine looks pretty good nestled in there!
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
67nukeford
Picked up an aluminum radiator from Alloy works. Pretty nice piece. Had to do a bit of trimming, to fit it around the steering box.
Pat 1967 F100 4WD
67nukeford
And installed. Looks good.
Pat 1967 F100 4WD
Love...the radiator! :thup:
I ran a two speed 18" electric fan, (from an 80's Pontiac Fiero) on my early Bronco for over 8 years and man did it help with the borderline radiator size Ford had to put into the V-8 Bronco's dud to frame rail width! :pop:
67nukeford
That one is a 3 core, should be plenty of cooling capability!
Pat 1967 F100 4WD
67nukeford
I did end up replacing the bottom side of one of the doors, on the inside. Came out pretty good.
Pat 1967 F100 4WD
67nukeford
Body work time. Started on the drivers side. This was a loooooong process. Got to a point, covered it in epoxy. Found a few spots still needing attention, and went back over those. sprayed epoxy again. There may be a spot or two I may have to address again next spring.
Pat 1967 F100 4WD
67nukeford
Same with the passenger side. I'll shoot high build next spring on both sides.
Pat 1967 F100 4WD
67nukeford
Off she goes to storage for the winter. So, I'll try and keep up with this next Spring when she comes home again!
Pat 1967 F100 4WD
Great progress. That door repair looks like it came out pretty good.
="67nukeford"Off she goes to storage for the winter. So, I'll try and keep up with this next Spring when she comes home again!
My RA has me hating winter, (even what folks call our "mild winter" here in Florida).
:cry: :cry: :cry: :cry:
Nice progress though and nice to see another perfectionist! :wink:
