What did you do to YOUR bump today?
- 68CamperSpecial
Re: What did you do to YOUR bump today?
Threw my surfboard in the back and went surfing
Learning something new about these trucks every time I log-in
- ToughOldFord
I put a quart of oil in mine yesterday. Thought about installing my trailer brake control and changing the exhaust doughnut. Decided as hot as it was that thinking about it was as far as I was going to get.
Faithful, stay away from my truck! She may be a 69, but she's still a virgin.
i got the carb return spring coil bracket and carb spring bracket under the coil bought today. just so i would havethe correct pieces for my 4wd. i seemed to have lost the carb under coil bracket fo rthe spring somehow. or i misplaced it.
- 1971ford
today i stared at the 71 in the driveway, then went around the side of the house and stared at the 69.
That was enough work for today.
-Ryan
- stephen44
1971ford wrote:today i stared at the 71 in the driveway, then went around the side of the house and stared at the 69.
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
Went to put a spool in my rear end, and pulled an axle shaft just to make sure it was right. Mines 28 spline, spool is a 31 spline.
Off to the junkyard to look for a 73-79 f100/150.
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
Finally have the money to get the gaskets I need to put the motor back together in my wife's truck. She's not happy her truck is broke. Hopefully replacing the head gasket fixes the problem.
Troy
The '73-'79 axles are going to be a couple inches longer than the earlier versions, so they won't fit in your existing housing. You'd have to get the whole dentside rearend, and then relocate it's spring pads inboard a few inches on each side to fit your bumpside.71fordkid wrote:Went to put a spool in my rear end, and pulled an axle shaft just to make sure it was right. Mines 28 spline, spool is a 31 spline.
Well nevermind. The only axles that have 31 splines in a 9'' are bronco axles, and theyre 28.5'' long. 2'' too wide for my truck, and i cant run a bronco axle.
double post, oops
Haha yeah i figured that out.FORDification wrote:The '73-'79 axles are going to be a couple inches longer than the earlier versions, so they won't fit in your existing housing. You'd have to get the whole dentside rearend, and then relocate it's spring pads inboard a few inches on each side to fit your bumpside.71fordkid wrote:Went to put a spool in my rear end, and pulled an axle shaft just to make sure it was right. Mines 28 spline, spool is a 31 spline.
- papabug71
I took my truck to the carwash this evening for a wash. I got it all cleaned up & was drying it off in the parking lot when a truckload of little $h*ts drove by & yelled out "OLD FORDS SUCK"..........................!@#$%^&*
Kids now days have no respect. Plus they were driving a Nissan Titan. Go figure.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- FormerMarine1981
papabug71 wrote:I took my truck to the carwash this evening for a wash. I got it all cleaned up & was drying it off in the parking lot when a truckload of little $h*ts drove by & yelled out "OLD FORDS SUCK"..........................!@#$%^&*
Don't let it get to you Papabug, When there truck is as old as ours are.... It will be molded into a coffee maker or something. I'm sure there will still be bumps driving than though
