Mustang/Cougar seat tracks question??
mljjones67
Post by mljjones67 »
Hey guys I wanna verify that these are the right seat tracks that work with the bucket seat brackets for our trucks?
thanks
http://cgi.ebay.com/ebaymotors/69-70-Mu ... 45f0279a8e
Re: Mustang/Cougar seat tracks question??
the angle bracket for the truck isnt there. they may fit but you still need the bottom angled brackets that bolt to the floor. i also want to know how the heck he is getting ups to ship them for only 10.00 i cant get that good of price on shipping seat tracks.
mljjones67
Oops I guess I should clarify my question. I have the special bucket seat mounts, what I don't have is the sliders for my bucket seats. I wanted to make sure these were the ones that work with the brackets before I buy them. Here is the seats that I want to use. I believe they are out of a later mustang?? Not sure though. I will hopefully be able to bolt the sliders to these seats and the sliders to the brackets then to the floor. Do the original bucket seats come with sliders??
dantheman71
Post by dantheman71 »
I would use the National parts depot catalog to compare what years need which tracks. They have a listing for 2 different bucket seat brackets for the trucks and those part numbers are the same in the Mustang catalog. You just need to figure out which Mustang seat you have and buy the right tracks for it I think....
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
yes the seats i have in the pictures are originals to that truck. they have sliders on them.
mljjones67
ok thanks fordman. From what I understand all the sliders from 65 thru some of the 70's mustangs and cougars are the same as our trucks. Is that correct?
Hawkrod
Post by Hawkrod »
Mustang/Cougar seat tracks are not the same as truck seat tracks. The original seat tracks for a truck had much shorter mounting studs so you can't use truck ones in a car but you can use car ones in a truck. The ones you linked to will work with the original floor barackets. Also note that many Ford seats used a standard bolt pattern on the base (but not all of them) so the seat tracks are very interchangeable when you are swapping seats. I used late model Ranger II seats and they bolted right to the original tracks with no modification. I have also done this with late model Tbird and Mustang seats when putting them in early Mustangs. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mljjones67
Hey Thanks Hawkrod. I wish I knew for sure what the seats are out of. I will take a photo of the seat tracks on there and maybe you can tell me what they are out of and what year.
As always hawkrod awesome
Hawkrod
Post by Hawkrod »
The blue seats look to be Mustang II or Granada (I am not really good on those) but look on the bottom of the seat for a metal tag attached to the springs. The tag will ID the seats (that is also how you can ID original truck buckets from Mustang buckets!). Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mljjones67
I had that tag somewhere. I could not find a decoder that would decode it. DO you have a book that would decode it?
Hawkrod
Post by Hawkrod »
mljjones67 wrote:I had that tag somewhere. I could not find a decoder that would decode it. DO you have a book that would decode it?
There is no book, just experience and knowledge. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mljjones67
HVR AT H598A 224-0
E1EB-6163101-AJ
I couldn't get it to focus but the numbers above are the ones on the tag.
Hawkrod
Post by Hawkrod »
I will have to look into, I responded but realized I made a mistake. I have an appointment but will be back in a short while and will check. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mljjones67
Thanks hawkrod. Take your time I am in no hurry. Your help is appreciated!!
Hawkrod
Post by Hawkrod »
I think the seats are 81 Ford Escort. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
