Will a seat from a 94 bolt into a 72?
Lebowski
Post by Lebowski »
Will this seat from a 1994 F-350 bolt into my 1972 F-350? If not what adjustments would be needed?
1972 F-350 w/9 ft. dump bed
2013 F-150 XL V6 Longbed
1952 Victoria 2 door hardtop
SteveC
Re: Will a seat from a 94 bolt into a 72?
Post by SteveC »
yes it will you have to dill the supports on the seat where the tracks from the 94 bolted in. the holes are already there just threaded and they drop right into the 72s tracks i have the same seat from a 87 in my 69 :thup:
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
Lebowski
Post by Lebowski »
I finally got ahold of the seller and he eventually told me that there is no adjustment on the seat to move it forward or back. My guess is it's a rear seat from a crew cab so I passed on it.... :(
ForingaMex
Post by ForingaMex »
You use the tracks from your old seat and I think the sliding mechanism is in the tracks. Is it not? Than you should be fine. I may be mistaken since I haven't done the swap yet.
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
the sliding thing is in the seat tracks it isnt made into the seat on any ford truck its in the brackets the seat mount on.
67nukeford
Post by 67nukeford »
So up to what year can you do this? I'd like to put a 60-40 split bench in , like my 97 has.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
zakt
Post by zakt »
1972 Ford F350 crewcab
Lebowski
Post by Lebowski »
If it is a rear seat out of a crew cab will the back fold forward? Is the back of a rear seat about the same angle as the back of a front seat? Would you recommend putting it in my '72 F-350 or should I keep looking for a front seat?
67nukeford
Thanks zakt!
Pat 1967 F100 4WD
i have no idea if they fold forward or not. it might not. but it might have a bolt on it that can be removed to let it fold forward. you will have to look at the seat to be sure.
zakt
Post by zakt »
I would get a front seat/s they will be able to move forward and back :2cents:
here check out this little write up conversion i wrote up. i hope it helps with the seat track part. http://www.fordification.com/forum/view ... at#p417834
MadMaxetc
Post by MadMaxetc »
Check out my website...that is the same seat I used with my original tracks.
http://members.cox.net/madmaxetc/1967_F ... nstall.htm
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
