bedliner in cab (pics)
underdog
Post by underdog »
I'm doing a complete tear down. I'm slowly in the process of putting everything back together. its a dentside. 1979 f250 w/460.
I used raptor bedliner. Its very easy to use- it comes in quart sized jugs that screww onto the spray nozzle. I welded a filler plate into the a/c hole. I'm putting an aftermarket unit in.
BobbyFord
Re: bedliner in cab (pics)
Post by BobbyFord »
Wow, that stuff looks pretty good.
hazelnut
Post by hazelnut »
you did a good job, cab should be a little quiter too.
wow that does look pretty good.
underdog
Post by underdog »
Thanks.
I've got it under the hood, under the cab, and in the cab. I'm switching to Lizard skin for the rest to see if it will hold up. I'll use it on the backside of the fenders.
underdog
Post by underdog »
painted and abs firewall installed:
flyboy2610
Post by flyboy2610 »
That looks sharp!
Don't forget to check out http://www.fordification.net/index.htm
Red Green
you'd better be right.
FormerMarine1981
Post by FormerMarine1981 »
That looks sharp. I have heard good things about the Lizard Skin. Good job on the build. Hope to see you on the .NET site.
underdog
Post by underdog »
doh! didn't know .net existed for my model year. Thanks!
The truck was taken down to the chassis, starting the reassembly.
PS- i'm sold my house in Austin about 6 months ago. Moved to Kempner.
austin
Post by austin »
looks good to me
