steering column
4b316
steering column
Post by 4b316 »
What is the difference between a manual steering column and a power steering column?I just listed a 72 column on ebay and I have been asked that question and just want to get it right.
AlleyCat
Re: steering column
Post by AlleyCat »
Manual columns and columns used with Bendix power steering are the same length. Columns used with Saginaw power steering are shorter. :)
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
Re: steering column
whats the link?
4b316
Re: steering column
Post by 4b316 »
Re: steering column
its hard top tell but it is probably for power steering being it is from a 73. but the end of the center shaft length is how you tell if is too long or not.
Hawkrod
Re: steering column
Post by Hawkrod »
And it isn't a Bronco column, 4X4 columns are different than 2 wheel drive columns. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
