door strikers
70RavenBlack
door strikers
Post by 70RavenBlack »
Does anyone know if the 73 and up strikers are basically the same and will fit a bump? :?
Re: door strikers
i cant be positive. but i think they are.
70RavenBlack
Re: door strikers
I can't find anyone who sells the 67-72, so I was curious. It looks the same with the exception of the newer model has a torx inset in the middle to loosen or tighten and ours have a jagged edge that I suppose is used for getting a grip on it with a pair of pliers and taking it out.
Darrman
Re: door strikers
Post by Darrman »
They are a different size bolt where they thread into the door jamb, I tried to switch to a new striker with the plastic bushings, no dice. May have not worked anyways, because of the plastic vs. metal bushing
Use a 12 point standard socket or box end wrench, cant remember what size, to get the old ones off.
hazelnut
Re: door strikers
Post by hazelnut »
The nut for the striker just sits in a carrage on the back side, you might be able to swap out the nut. havent looked at a dent to see if there the same size, but just a thought.
Re: door strikers
thats a good idea if the striker is the same size and nut threads are larger.
Ks Highboy
Re: door strikers
Post by Ks Highboy »
They are diff. I just tapped my old striker plates and screwed them in .
