Emergency flasher switch 68-72
jp2005
Post by jp2005 »
Will 70-72 fit the 68 switch in grove box? LMC, DC and other places dont carry 67-69 switch Thanks guys
70_F100
Re: flasher switch
Post by 70_F100 »
I'm pretty sure it can be made to work with a little re-wiring.
I think Fordman has commented on this in the past.
jp2005
Re: flasher switch
Post by jp2005 »
mmm ok
Re: flasher switch
it will plug into the wiring. but i dont know how to mount it without using the 67-69 bracket. you can probably take the old one apart and clean it up and it will work again. as far as finding a good one that works. i may have a 67-69. maybe not though. i know i have the 70-72 type. but you can find them on ebay too. search for mustang failrane truck hazard or flasher switch. http://cgi.ebay.com/ebaymotors/1966-Mus ... ccessories
jp2005
Re: flasher switch
Post by jp2005 »
Thanks guys again!!!!
