Steel dash
White Lightning
Steel dash
Post by White Lightning »
Guys, the main frame of the dash...right below the glove box that goes all the way across? Is that replaceable? The one in my truck has a dent in it and I'd rather not have any bondo work done to fix it.
Re: Steel dash
well you can remove the whole dash and replace it but it is alot of work. you can also cut out and weld in a new piece. but then you might have to use some bondo to fill little welding pits and so forth. maybe not depending on how good weld and grind off the welds.
