Guys I need your input. I put 24.1 miles on new speedo cable from LMC. Cable broke about 1 1/4" from screw assy. behind dash cluster. Why would this happen? I have good smooth bends in cable,(LMC cable is about 2' too long), I poured plenty of speedo cable lubricant down tube at time on install. Should I replace inner core? Try Mac's C5TZ-17260-Y? I wanted to mention this is frame off total restoration, everything apart. Failed to mention- 68 F100, 360 w/manual 3 speed on column.
Thanks
Speedometer Cable Problem
- 70_F100
Re: Speedometer Cable Problem
Check to make sure your speedometer head is not binding.
That's not an oil leak
