dent in a bump...wild
shortstack
Post by shortstack »
I bought a truck a while ago for the mean 390 it had. I got to looking at it and it was all pretty normal. I was out at the "parts department" the other day and noticed the dash in the ole' 67'...
1971 f100 Custom, SWB, 302, T5
"It can't be that hard."
Hawkrod
Re: dent in a bump...wild
Post by Hawkrod »
It isn't too hard of a swap, the 73-79 dashes bolt in so all you have to do is cut out the top of the old dash and unbolt everything. The wiring plugs are different but the circuits are the same so splicing wires ends up being the hard part. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
i seen someone put a bump dash in a dentside. it was on ebay a few years ago.
Hawkrod
Post by Hawkrod »
fordman wrote:i seen someone put a bump dash in a dentside. it was on ebay a few years ago.
Large dents came with a bump dash. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
this one was a regular F150 or F250. 4wd too.
Hawkrod
Post by Hawkrod »
fordman wrote:this one was a regular F150 or F250. 4wd too.
Yes and cab swaps are not uncommon. It is a pain but not too hard to put an F600 cab on an F250 4X4 and I know because I am in the process of using a dent F600 cab and front end on one. I am still trying to figure out what I want to use for the back fenders so they match the front. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
fireguywtc
Post by fireguywtc »
could have been a large dent cab swap too, maybe.
Bill
2024 F350 CCSB, darkened bronze
i talked to the ebay seller. and he said it wasnt hard to put the dash in the dentside. so it wasnt a cab swap.
