key won't turn!
1971ford
key won't turn!
Post by 1971ford »
So I've been starting hte highboy with a screwdriver (no key cylinder installed yet) and today I installed hte key cylinder into the ignition. key cylinder/keys are brand new from NPD.
I install it, turn the key, everything works. Pull the key out, put it in, can't turn it AT ALL. GREAT. Now I can't even pull the lock cylinder out so now i can't even start my truck with a screwdriver.
WTF can I do? I don't see any way to pull the lock cylinder out without being able to turn the key to acc position.
I'll see what NPD has to say, they have disappointed me this time... can't even drive my daily driver now
-Ryan
1971ford
Re: key won't turn!
Post by 1971ford »
After an hour of calling every NPD store I finally found out which one i bought it from.
They said they might be able to give me a new lock cylinder but not an ignition switch.
So now I need an ignition switch too!!!
-Ryan
Re: key won't turn!
if yo uhave time to mess with it. wiggle the key up and down in and out while you try to turn the key. then try flipping the key over to see if that will work.
1971ford
Re: key won't turn!
Post by 1971ford »
Yep tried both keys, both sides, puwiggle wiggle wiggle,
I finally trashed the whole deal.
Then I went to the junkyard and cut off a 1971 ignition plug, then grabbed the ignition from the '71 race truck, swapped that and the key cylinder into the '69 and swapped ignition plugs for the blade type. Now the '69 has a fully functional ignition with key. Works great.
But now the race truck has no ignition at all so I need to get another blade style ignition housing to put in the '71, then I'll put the '71s lock cylinder back into it, and I'll put the new NPD lock cylinder into the '69 that they are sending me again.
Sent you a PM about it Fordman.
-Ryan
Mancar1
Re: key won't turn!
Post by Mancar1 »
That is why you have more than one. So ya can rob Peter to pay Paul. Makes sense to me. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
1971ford
Re: key won't turn!
Post by 1971ford »
lol seriously. I have taken so much off the '71 already to make the '69 my daily driver...
I've started a list so that when i put the '71 back together near summer time I know what i don't have lol
-Ryan
69rangerf100
Re: key won't turn!
Post by 69rangerf100 »
wow sounds like you are getting nothing but trouble Ryan sorry to hear that
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
