Wing noise
Mancar1
Wing noise
Post by Mancar1 »
When :drive: my 68 the wind noise caused by the wings is annoying :shh: . Has anyone put new handles on, and does that tighten them up enough. About ready to send one to my brother-in-law machinist so he can make me a couple caps or new assemblies with extra lenth to the tips.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: Wing noise
if the plasitc tip is worn off a new handles may help the noise. but it could also be the worn rubber around the glass and frame. or here is another solution.
Mancar1
Re: Wing noise
Post by Mancar1 »
Thanks fordman. Rubber is new, and I am currently doing something similar to what your pics. show. I'm using a bud cap plus a washer. :) For now wind noise dropped a lot.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
mybros71
Re: Wing noise
Post by mybros71 »
Un-cork your exhaust. You'll forget all about the whistle.
I put a large vaccuum cap with a short piece of hose in the bottom over the latch. It's not quite so noticable and seems to work pretty good.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
Mancar1
Re: Wing noise
Post by Mancar1 »
mybros71 wrote:Un-cork your exhaust. You'll forget all about the whistle.
Thanks for the hint. My exhaust makes some sweat music, (Glasspacks). When I get more ump on the 390, I will uncork it some more. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
19agin
Re: Wing noise
Post by 19agin »
Okay, so if I don't want to have bottlecaps or folded up business cards under my wing window latches, does replacing them fix the problem? The tips on mine appear fine, but the latches themselves seem to have some movement. When you replace the latches, does that fix the air noise?
Third Bump's the Charm! 1971 Sport Custom - 360 - C6
Mancar1
Re: Wing noise
Post by Mancar1 »
Yes it should help if you buy new ones. after a lotta years they get very loose and the tips wear. That is two of the many things I plan on getting.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
19agin
Re: Wing noise
Post by 19agin »
A friend has replaced the weatherstrip around his wings, he got it from LMC, one will not hardly close and has gaaps in it. I think if it is the weatherstrip, it would just be the staight one that the wing seals to. I don't know if you can get just that piece without ordering a whole set of stuff.
Re: Wing noise
i think its all one kit or piece. lmc doesnt have good rubber from what i have read.
