dash controls and heater
element7878
Post by element7878 »
First off all the vents and ducts weren't in the truck when I got it..but I did have the motor under the dash..everything after the motor was missing..today I hooked the motor leads up and the motor ran..my question is, did these motors have speeds or were they just one speed? Also there are some more electrical connection tabs on the backside of the motor..curios as to what those are...I made my connections directly to the two wires coming out of the motor..
1967 ford f100 Shortbed
Ford 360,edelbrock intake,holly 4bbl 600,rv cam
San Antonio, Texas
71highboy
Re: dash controls and heater
Post by 71highboy »
more details on year and model of the truck please :fr:
element7878
1967 f100
San Antonio, Texas
Caseys71
Post by Caseys71 »
Not sure what the connections you are referring to go to right off hand, however the motor did have more than one speed to answer that question. IIRC it only has a high and a low setting though but that is controlled through the switch itself.
Casey
the power goes to the switch. fom th ewiper motr switch from there it goes to the resistor behind the heater box and then to the motor. the resistor controls the fan speeds. i dont think i have any pictures but here is the diagram of how the wiring goes. or how the box hooks up to it. the defrost ducts are the only other ducts that come off of the box.
http://www.fordification.com/tech/wirin ... wipers.jpg
http://www.fordification.com/tech/wirin ... ghts02.jpg
http://www.fordification.com/tech/image ... heater.jpg
element7878
yea those diagrams are confusing ha....Why would it go through the windshield wiper switch first? So the switch has two positions? I need to go see if i can find one at the junk yard...So im thinking maybe those tabs im talking about are the resistor? And im also assuming that the resistor would make it do low speed, and just direct 12v will make it do high...Like i said when i just wired it direct it spun like it was on high. Could I just run a direct hot wire to the switch and not deal with running it to the windshield wiper swich first? I may try to run the direct wire i had through those tabs first and then to the motor and see if it makes it run slower..thanks for all the help...It was pretty cold the other night driving it home from my friends without a heater...
San Antonio, Texas
the power for the heater swithc jumps off of the wiper switch power. and the wiper switch power comes from the wiper fuse.
element7878
yea i ran the hot through those two tabs in the back first and then to the motor, and it made it run slower...just need to get a switch
San Antonio, Texas
element7878
Found a switch today at a junkyard for 12 bucks...also got a headliner for 10, and the visors for 10 for the pair...not bad i guess
San Antonio, Texas
