wing window glass installation
70SportCustom
Post by 70SportCustom »
Has anyone replaced the rubber material in the wing window, where the glass meets the metal bracket? I tore down my wing windows to replace the rubber and powdercoat the window frames. the glass was super dificult to remove, but once I did I was able to clean up the frames by bead blasting the frames and powdercoating them. Do the wing window seal kits come with anything for this? what do you use to put the glass back in the frames? thanks
-Warren
Re: wing window glass installation
the local glass shop told me 4.00 per wing to put new rubber in them for me. so i am just going to let them do it. that is rubber and labor 4.00 total. so 8.00 for a pair.
