Should I install Firewall Cover or not?
I just installed the carpet from ACC carpets( Great fit btw) on my 67 F100 4WD. I took out the old firewall cover, it could not be saved. Has any one NOT put a new Firewall cover back and just left it without one? Can you give me the pros and cons....the cost is 175 plus shipping from Carpenter...Thanks!!!
Re: Should I install Firewall Cover or not?
Pro: It's about an inch of insulation that helps keep engine compartment heat out of the passenger compartment.
ACC does make great products and I've used them for years. Beats getting an old carpet remnant and messing around trying to make it look right. How about a pic of the carpet installed!? We would all like to see.
1955 Ford Customline
1969 F100 SWB 302, 3 speed
1973 Mustang Convertible
1986 F150 5.0L auto, bought 4/2/10
1989 Mustang GT H/B
1989 Mustang GT H/B
you dont have to buy a new one. but you should put one back in. you can use insulation and carpet on it. as they did in the ranger xlt trucks. jute carpet padding is a the same insulation ford used behind the firewall cover.
Thank you guys....any ideas on where i might find a decent used one?
i have a used one. it may be expensive or hard to ship. it is kind of delicate. but a local junkyard or craigs list might be agoo place to find one.
- mrtleavitt
I drove my truck around during its build w/o a firewall cover and it got soooo hot inside the cab! It was about 100 degrees outside and like 120 degrees inside. I would definitely buy one.
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
- Joshpow
Mine has carpet bout half way up firewall and thin insulation. Id put something back for heat. Pros to none.... You can hear the noises beter!! Cons.... Heat and noise! Maybe dynamat the firewall and continue the carpet up under the dash. Make sure you glue the carpet to the firewall good though. Guy didnt on mine and it fell off into the floorboard!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
dynamat or something equivalent would work fine!
1967 f100 styleside
- sublimer
I was considering making my own firewall.
I had pretty good luck carpeting my truck myself from stuff from Lowe's for about ~$30 and 14 hours of time
, I figured I could apply a similar principle to the firewall cover. The plan in my head is...
1. Remove the current one
2. Install some sort of insulation using spray adhesive (I'll continue to use what I put under the carpet, house insulation like dynamat that comes in a roll at Lowe's)
3. Go to Jo-Ann Fabrics and get some fake-leather vinyl/PVC/Pleather or other material that would look nice. Bust out a sowing machine and make some stitches in the bottom to simulate the look of the factory one (see picture)
4. Cutout holes and install using whatever method I please
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
Moveable Speakers
