Homemade sandblasting cabinet
Swegner99
Post by Swegner99 »
Anyone ever done anything like this? Seems very cost effective....
http://www.smecca.com/2011/02/how-to-bu ... g-cabinet/
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
71PA_Highboy
Re: Homemade sandblasting cabinet
Post by 71PA_Highboy »
Check TPTools.com.... They have a kit with many of the parts... you supply the plywood.
Edit: http://www.tptools.com/dg/142_Abrasive- ... -Kits.html
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
Swegner99
Post by Swegner99 »
That is an awesome kit, think thats going to be next on my list of must haves!
1999 F150 Ext Cab
71PA_Highboy
When you are ready, let me know and I will send you some pics of mine, and the mistakes I made...
Mine is a full 48 wide inside...
Got Ford?
1 Lincoln Mark VIII
flyboy71
Post by flyboy71 »
Heres mine. Plywood, crude and works ok. Im using a bucket blaster and it works ok. Yep those glove "holders" are tops from small drywall pails. They fit snug and seal the gloves very well. The tacky paneling chute obviously wasnt attached yet.
-Jeff
SVT522
Post by SVT522 »
I got one from Harbor Freight for less than $200 when it was on sale and with a 20% off coupon. It works great and all I had to do was put it together in less than an hour and start blasting.
http://www.harborfreight.com/40-lb-capa ... 93608.html
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
hdpusher
Post by hdpusher »
A few years ago I needed a cabinet and I checked into the kits. I figured it was not worth my time and materials to try and make one. My cost factor was considering if I had to buy everything new plywood, gloves, syphon blaster, plexiglass exct. So I went the cheapo Harbor Freight route and Im glad I did. The cost of the HF was under $180 on sale with coupon. I added my own reclaimer system to keep the dust down and it worked better than most homemade blast cabinets Ive used. :2cents:
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold :cry: )
78 CJ5
03 Dodge Cummins
I built this paint booth in my "basement" last winter when it got too cold to paint outside.
5' wide x 4' deep x 6.5' high. I hang some heavy gauge plastic over the filters, roll down the door and suit up in a Tyvec paint suit with a dust mask, goggles and a faceshield and blast my A$$ off with a $30 pot blaster. Then I just sweep it into a bucket and pour it through a screen back into the pot. Pull the plastic down and start painting. It's a little hot and sweaty but I can blast my I-beams, fender aprons, hang small parts, heavy parts, anything that I can get in it.
