re alternater
1968_ONEHUN
re alternater
Post by 1968_ONEHUN »
Hi guy's.I picked up a new alternater today.Was wondering,are they supposed to get a little warm?Never noticed weather they do or don't before.
1968 F-100 Custom Cab
300 6cyl 4spd
If it ain't broke,what the hell, fix it anyways !
1968_ONEHUN
re: re alternater
Thanks for the reply.The battery was pretty low on charge when I installed the alternater,so mabe thats why.I had the regulator off,and it looked fine on the inside,I do have a spare one,mabe I should put it on,as I'm not to sure how to test it.What do you think?
300 6cyl 4spd
heep70
re: re alternater
Post by heep70 »
You will need a volt meter. Attach the red lead to the positive on the alt and the black lead to a ground. Increase the RPM and if the alt is charging properly it will read around 14.3.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
oldschoolrods
re: re alternater
Post by oldschoolrods »
if you don't have a voltmeter, i picked up an alternator tester at radioshack for $5, you just hook it to the battery while its running and it tells you if your system is charging properly, its not as effective as the voltmeter but it works.
