harbor freight torque wrench accuracy?
caseyj10
Post by caseyj10 »
Now that it time to reassemble my 302 I am worried about the accuracy of my hf torque wrench. Has anyone has their hf torque wrench tested for accuracy?
caseyj10
Re: harbor freight torque wrench accuracy?
Post by caseyj10 »
Sorry if this is in the wrong section, forgot there is a tool section. But this does involve me assembling my engine so I suppose it still fits?
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Post by 1970 Hi-Boy »
:2cents: Just the fact that you had to pose the question, should in itself be a part of your answer. Ask yourself this, would you want engine parts made by the same people that made your HF torque wrench? I didn't think so, don't let your engine build go down the drain from a questionable tool, it's not worth it. Quality tools always pay off in the end, as they will serve you well by getting the job done right the first time and will give more than a lifetime of service. If you can not afford one now, I would borrow or rent one to be sure the engines fasteners are torqued properly. :thup:
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
DuckRyder
Post by DuckRyder »
You may (or may not) find this thread useful.
http://forums.pelicanparts.com/porsche- ... nches.html
FWIW, I probably would not use it.
