Cargo Light Problems
dcbullet
Post by dcbullet »
If I turn on my cargo light the 15 amp fuse will blow. Looking for advice as to common problems that might cause it. The wiring appears to be correct, as I have the wiring diagram and it all seems to line up. Could it be the switch itself that is bad?
Thanks in advance.
hardtailjohn
re: Cargo Light Problems
Post by hardtailjohn »
Nothing's impossible.... it could be the switch. I'd pull the bulb and take the wire off the switch, then test with an ohm meter from the end of the wire to ground and then disconnect the power from the switch and do the same... sounds like there's a short somewhere in there to me.
John H.
yea it sounds like a short to me also.
dcbullet
Post by dcbullet »
And a short is when exposed wire is touching bare metal?
spartman
Post by spartman »
Correct dc!!!
well its when a hot wire is crossing over to a ground. thats what makes the fuses blow.
Faithful Old Road Dog
Post by Faithful Old Road Dog »
I'd start by cecking out the switch and the connections to the switch. Then I'd check the wiring since those run through the pillar along the roof rail to the back cargo light. Lots of area for the coating of the wire to wear and ground.
dcbullet
Post by dcbullet »
Something to do on my Thanksgiving weekend! :evil:
