Highbeams in 79?
Chromepro
Highbeams in 79?
Post by Chromepro »
Anyone know if highbeam switch was still on the floor or on the column in 1979? :hmm: Doing a 68 to 79 column exchange, so this might be good to know.
hardtailjohn
re: Highbeams in 79?
Post by hardtailjohn »
Should still be on the floor... where they belong.
John H.
oldhalftons
Post by oldhalftons »
yes, they are on the floor until at least 87 (parting out a 87 f250 and its on the floor)
btw: You'll have to run a ground strap over your rag joint to get the horn to work on the 79 column. they changed the way they grounded in 78.
1969 F100 300/4spd power steering, manual brakes
spartman
Post by spartman »
I had an 88 that still had the dimmer switch on the floor.
Ford_Doctor
Post by Ford_Doctor »
1991 was the last year for the floor mounted high beam switch on f100/150-350.
Chromepro
Post by Chromepro »
I understand that the horn has two wires, so could I ground one, or does the column need to be grounded to maybe a box bolt?
