Was there such a setup
spartman
Post by spartman »
I was wondering if our trucks or any vehicles for that matter came with disc front brakes but no power booster.
Kinda like manual disc brakes?
Just thinking out loud again.
68F250
re: Was there such a setup
Post by 68F250 »
Early Mustangs had manual disc brakes as an option.
'73 and later F100's came standard with manual discs.
Barry
spartman
Post by spartman »
Okay thanks again barry.
So then how did they work vs the power versions?
68F250
Post by 68F250 »
I can't imagine they worked that great but I've never driven one. Pedal effort has to goes up, disc brakes take about twice the line pressure to lock-up vs drums.
A power booster doesn't rob any HP from the engine.
Barry
spartman
Post by spartman »
I know that the booster won't take any power away.
This was more of a thinking out loud, wonder how it would work kinda things.
QC
Post by QC »
The 74 F-100 that I got my disc brake axles from did not have power brakes.
69 F-100 Ranger 302
mcarlson11
Post by mcarlson11 »
If you want to see how they feel, just turn motor off while driving and press the brakes a few time, you will see how hard it gets.
Pro-Street/StateTk
Post by Pro-Street/StateTk »
I have had lots of 73-79 ford trucks with manual disc brakes and I must say I
really like how they work, feel, and stop, but when I swapped my 65 truck
to discs I did swap to power discs because you don't have to use as much
presure and you don't have to lift your leg from the floor as high!
But if I were buying a 73-79 I would not swap it to power!
8) 8) :)
Cut ( FOUR ) pieces of an old ford truck frame that has been junked, fit them to the inside of your good frame, add weld and bolts, the leafs are now inboard, time for the (big WIDE tires)!
Oh yeah (Tubbs)
72hiboy4x4
Post by 72hiboy4x4 »
QC wrote:The 74 F-100 that I got my disc brake axles from did not have power brakes.
hehe you beat me to it, QC! I was about to post about that same truck!
