manual brakes?
manual brakes?
hey all you guys (and girls), i have a 1970 f250 sc, with manual brakes and power steering, im just wondering how my manual brakes should feel because right now, i kinda have to pump them, even though i have a new mastercylinder. ? thanks......Jeff
"NOTICE, Insanity has replaced all reason in the design and construction of this vehicle"
1970 F250 Sport Custom, 360FE
1964 Thunderbird, 390FE, Offy intake, holley 4bbl,cam, open exhaust
re: manual brakes?
have you bled the brake lines? Did you table-bleed the new master cylinder before installing it? If not, that could cause air, which means more pumping.
it's a 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70 automobile!
re: manual brakes?
hombre, yes i did "bench bleed" the Mc , but i didnt bleed new(fresh) fluid the whole way thru the system, so that could be the problem
- 460 crew
Yep, you may have air trapped in there from the switch. Plus new fluid through your lines is a good idea.
- mrung0wa
re: manual brakes?
Yup!
Not flushing and putting new BF your system is like taking a dump and then not wiping afterwards or doing changing engine the oil without replacing the filter...
Lawrence
Lawrence
Re: re: manual brakes?
You sure have a way with words!mrung0wa wrote:Yup!
Lawrence
- mrung0wa
Yeah Keith I guess I really do!
Back in 85 when I was attending SDSU I worked at this Chevron station driving a Tow Truck. Well one afternoon this dude walked up to the boss and asked him if he would do an oil change without changing the filter. There were a couple of us guys standing around BS'n so Bob (the Boss) responded with "When you take a crap, do you wipe afterwards? None of us could believe what we'd just heard. The dude was with his girlfriend but he put his "tail" between his legs and without muttering another word scamperd away nevr to be seen again.
Wow that was a unforgetable experience that afternoon.
Lawrence
Lawrence
- willowbilly3
re: manual brakes?
You may also need to adjust the brakes.
re: manual brakes?
Is it possible to get the system bled without "bench bleeding" the master cylinder. I got in a hurry and installed it without "bench bleeding". I am using a vacuum pump to bleed each brake cylinder (not done yet). Am I chasing my tail or will it just take longer?
- 460 crew
Just takes longer and make sure you keep filling the MC and not letting it suck dry till your air free.
