Fuel filter change
1guydude
Fuel filter change
Post by 1guydude »
Hey how do i change this.metal.screen type filter in the bottom of.my.fuel.pump?
Do i have to remove the pump and rinse it.all.out? Is there a sleeve type that goes.over this.metal.screen? Should.i just buy a new one and replace this unit? Gonna flush the whole gas system since the previous owner said he did it but obviuosly a.poor.job or not at all.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
colnago
Re: Fuel filter change
Post by colnago »
Can you post a photo? I can only picture the pleated paper filter in the fuel pump. What truck/engine is this for?
Joseph
1guydude
Post by 1guydude »
This is the only.image i can find online. I have to google image 1965 mustang fuel filter change.
Maybe ill put some gloves on and give it a good.tug.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
ThinLizzy13
Post by ThinLizzy13 »
The metal can screws off and you replace the filter that's in there. Mine have always been paper.
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
:yt: I gave you that info in a prior post. http://www.fordification.com/forum/down ... &mode=view
1guydude
Post by 1guydude »
Yup and i bought a new one. This one isnt paper but metal. Wouldnt come out yesterday. I used needle nose pliers and my hands. Gonna glove up and tug it.maybe later today of i get a chance
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
ThinLizzy13
Is the can cover stuck or the filter inside stuck to the pump?
1guydude
Post by 1guydude »
The filter. I have a pvc wrench that made short work of the canister.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
colnago
Post by colnago »
In your picture, 9355 is the outer canister. It should screw off. The ring at the top is a rubber O-ring that goes on top of the canister to seal it. 9155 should be the paper pleated filter. It should simply pull off in the downward direction. I've never seen reference to a metal filter. Are you sure you have a Ford fuel pump? If not, maybe it screws on, or maybe there's a retaining nut on the bottom of the filter.
Joseph
1guydude
Post by 1guydude »
I tried to unsrew it as well. Just turned and turned.
I think whoever dropped the 360 or.390.in my truck left the original everything for everything. Lol
Its shows just an o ring in the diagram i found. Ill post a pic.of the metal screen hopefully.later when i drain the fuel that comes out and pull that canister.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
If anything ill.put a rag around it and rip it.out. try and put the new paper one in. I didnt wanna break anything yesterday but right now im at the point were ill replace the whole mechanical.pump if i have to
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
colnago
Post by colnago »
Here are some photos of what I have. Hope these help.
Joseph
Yep, same as mine.
1guydude
Post by 1guydude »
Yes i have the same set up. My filter element is not the paper one as pictured. I have a metal one with holes in it like the diagram i posted above...
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1guydude
Post by 1guydude »
As soon as the lady gets home. Ill pull the front end in the garage out of the rain and show u all.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
