72 F100 4x4 Build
- 1968-f250
72 F100 4x4 Build
Well, I've always wanted a 4x4 bumpside, so when I stumbled upon this one for $250, I have to grab it. The body is completely shot since it was used and abused by a construction company, but who cares, all I wanted was the frame. This is going to be a long term build since I still need to get my 68 250 painted and the bronco, so most of my funds will be going towards those. My future plans for the truck include sandblasting and painting the frame, all new bushings, and 4 in lift with 35s. Once that's done, I'll look into the body. Since it won't be a daily driver, I could care less about mileage. I bought it without an engine, but I already have a 390 I'm working on to drop in it. Now, onto the pictures!
This is the day I brought it home.
Like I said, it's beat up and rusty. So, first order of business was to tear the rusty box off.
Then I did some patching on the inner fenders so the hood could go back on, and then put some 31's on it. Much better.
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1957 Ford Fairlane 500 convertible (x2)
1979 Ford Bronco (x2)
1956 Ford Thunderbird
When the going gets tough, switch to power tools -Red Green
1964 F100 Short box
1968 F250
1972 F100 4x4
- 1968-f250
Re: 72 F100 4x4 Build
I also found some parts on craigslist for it.
A pair of brand new fenders
Really good inner fenders. You can see the patch I did on one of them. I'll go more in detail with that later.
One 67-69 upper valance, and a 70-72 upper valance
67 steel grille
67 aluminum grille
I have a rust free radiator support in my parts bronco that will go on this truck, and it came with a usable hood. I also have a decent pass. door left from my 68 f250 that just needs a skin. If I'm crazy enough, I might try to fix the cab...
Anyone have an idea of what that aluminum grille is worth?
67 steel grille
67 aluminum grille
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- 1968-f250
72 F100 4x4 Build
Like I said before, the pass. inner fender that I bought needed a patch. It rotted out where the battery tray would have been, a very common spot as it seems.
Here is the rusted section is question
I made a patch in two pieces so it would be easier to form
Then I cut out the offending rust
Then welded the patch in
And after some time with a flap disc...
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- Manny
Holy smokes that thing was hammered!!!! Still i see the $250.00 quick. No doubt i would have bought it. Know the pain of 4 projects so i wish you the best on this one. Looks like a great start. Hopefully you saved what was left of the bed side toolbox??? Can't wait for more.
Don't worry, that body with buff out no problem.
What a score! Hopefully the frame isn't tweaked with all the bashing it took. Still for that money you can't go wrong. What if you put your nice 68 body on it?
Even smashed up with no bed it looks tough. You could do a rat rod type build. I've always wanted a highboy with a tow truck bed.
Kyle
Kyle
- 1968-f250
I still have to remove what remains of the tool box. The bottom of the box is completely gone, but the door might be savable. I still need to pull the tailgate supports off of it also.Manny wrote:Holy smokes that thing was hammered!!!! Still i see the $250.00 quick. No doubt i would have bought it. Know the pain of 4 projects so i wish you the best on this one. Looks like a great start. Hopefully you saved what was left of the bed side toolbox??? Can't wait for more.
hfdco4 wrote:Don't worry, that body with buff out no problem.
I guess we will see... The cab does look like it could be saved. With a lot of hours though...
The frame is in really good shape. No rot, and the radius arm ends look to be very good also. Sadly the PO hacked up the front frame horns a little bit. I must have had a plow on it at some point. There is also some crap welded to the rear frame, but it'll grind off.Lone Ranger wrote:What a score! Hopefully the frame isn't tweaked with all the bashing it took. Still for that money you can't go wrong. What if you put your nice 68 body on it?
My whole plan at first was to do a body swap, but I came to my senses and couldn't rip apart the 68. It just performs so well that it would be a shame, and I'd like to keep it original since it is my great grandpa's old truck. There is enough parts for sale locally to put a whole new body on it, but I don't have the funds at the moment. I gotta get the 68 painted soon or I'll go crazy! Hopefully I can start to get some quotes on a paint job soon.
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- Manny
Cool just saw some hard to come by parts. Hopefully you can save it and get it stitched into your new bed. Don't see to many on 100's1968-f250 wrote:
I got a bunch of body panels off eBay. Galvanized and primed fenders were like 140 each and inner galvanized fenders were like 200. I liked the idea of galvanized cause it should never rust. It would be a shame to tear up your gramps old truck... And why not have two bumps?!
Kyle
Kyle
With everything we have seen you do to the 68, painting it shouldn't be a problem. Look at some of the single stage paints that are available. You can do it yourself and save thousands of dollars!!!!!!!
- 1968-f250
That sounds pretty interesting with the galvanized parts. Should hold up really good.Lone Ranger wrote:I got a bunch of body panels off eBay. Galvanized and primed fenders were like 140 each and inner galvanized fenders were like 200. I liked the idea of galvanized cause it should never rust. It would be a shame to tear up your gramps old truck... And why not have two bumps?!
That was the original plan, but I don't know anymore. It still needs a good amount of finish body filler work to make it look presentable, and I'm not sure if I'm capable of making it look how I want it to. I brought it to a guy who does really great paint jobs locally, and he was thinking between 5 and 6 thousand to do the truck. But, he is a perfectionist, and I've seen the work that he has done. I guess we will see what happens.hfdco4 wrote:With everything we have seen you do to the 68, painting it shouldn't be a problem. Look at some of the single stage paints that are available. You can do it yourself and save thousands of dollars!!!!!!!
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
- Manny
5 to 6,000 is up there. I would say pour the labor of love into it myself. Of course nowadays material seems to just be going stupid for good paint. What color and material going to be using PPG?
You could always paint it yourself to get by then save up for a pro paint job down the road.
Kyle
Kyle
- 1968-f250
Lone Ranger wrote:You could always paint it yourself to get by then save up for a pro paint job down the road.
Well, the decision is final.. I'm going to paint it myself! I actually started sanding today. I'm not sure on what supplier I'm going to go through for paint, but it will be getting a coat of Harbor Blue by the end of June if all goes well. I'll be updating that build thread shortly.Manny wrote:5 to 6,000 is up there. I would say pour the labor of love into it myself. Of course nowadays material seems to just be going stupid for good paint. What color and material going to be using PPG?
The 72 is kind of on hold until I can get a chance to go through the heads, and I'll be putting most of my time into painting the 68.
-Ray
1964 F100 Short box
1968 F250
1972 F100 4x4
1964 F100 Short box
1968 F250
1972 F100 4x4
Great, just post some pics of the body work on your other thread.
