help
help
HI guys I like to know if those would fit on my 67 for a 302 swap dont know the year of the frame that they are on sombody can see by the pic hope sombody can help me please 5 pic 2 post
Re: help
Those look about right for small block stands. http://www.fordification.com/tech/engine-perches.htm Here's mine.
Re: help
They'll work. Just pay attention to the hole locations. The crossmembers and frames were drilled for all variations of engines. Just make sure you use the small block holes. You can zoom in on my photo and see which ones to use.
Re: help
When I took my 240 I-6 out and put in an 86 302 mustang engine in my 69 f100, I had 2 drill 1 hole on each side. The front cross bar is different from 67-69 vs 70-72 The 67-72 is stronger (has inside channel) 70-72 does not on 2wds.
