rear hub removal
- 19674x4
rear hub removal
ok, i was going to do my brakes, on the rear but i went to take the rear hubs off and they didn't budge, i removed the outer bolts but could not get it to move, any tips or tricks to removing these old pigs.
My Photo Album
2012 Cummins-the luxury Tow Pig
1967 F-250 highboy 352, np435(((((((sold))))))))) My first true love
1968 F100 SWB. 360, np-435, flatbed, currently acting as a hornest nest and bee hive.
1971 F-100 4x4 Step-side. 360, np-435, 70k origional miles- needs allot of love.
- ToughOldFord
re: rear hub removal
The 3/4 tons have a floating rear axle. You have to remove the axle shaft and then the large nut on the axle spindle, the lock washer under that nut, then the nut under that. Then your hub comes off.
- 19674x4
i could not get the outer part off, the one that has a bump that looks like the handle on a lock in lock out hub. the 6 or 7 bolts hold it on. has a metal spacer or gasket behind it?
My Photo Album
- ToughOldFord
Give the center a whack with a hammer to break it loose.
On mine it has studs with nuts rather than bolts and I have to hammer it to get the coned lock-washers high enough on the studs to pull them out with a screwdriver or pliers. On rear ends with bolts this isn't a issue.
Either way those bolts or studs are all that hold that shaft in place.
- ToughOldFord
Here's a pic, from a Dodge forum, but still a dana;
- ToughOldFord
Here's a strange, I know Ford went to outboard drums, (pull the drum off the hub separately), in the late 80's, but here's an old one without the drum:
- 19674x4
the opne off the dodge is it, it has nuts, my bad
My Photo Album
- ToughOldFord
I wasn't clear on that second pick, that one is a Ford according to the site I found it at.
That's how mine is too, so you need to pound on the end enough to get the coned shaped split washers loose enough to pull off then the axle shaft will slide out.
- Sharkdance
- 68F250
Those cone washer thingys can be a pain. What I've done before is to remove the nuts first while the truck is still on the ground and then rock it back and forth in park. It works the little guys loose enough to pull out.
Barry
- 19674x4
thanks guys.
My Photo Album
