Radio Delete Plate or AM Radio
- Idaho Chris
I'm looking for a radio delete cover plate for my '69 (any color, I can paint it) or a working factory push button AM radio for same. Thanks!
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
Re: Radio Delete Plate or AM Radio
I have a delete plate if I can find it.
- Idaho Chris
Great Jeff! I'll hope to hear back from you when/if you find it. Just PM me what you want for it. Thxjunkyardjeff wrote:I have a delete plate if I can find it.
-Chris
I think its in the garage and will look after work tonight.
I have an AM radio I am not using. From a 67 f100
1967 F100 Shortbed
1978 F250 Crew Cab
1979 Bronco Custom
1996 F350 Diesel 4x4
1962 & 65 Econoline Pickup
1988 Ranger
I Love Fords and fur babies.
That about sums it up.
-Jade
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
- Idaho Chris
Jaddie-Jaddiethelady wrote:I have an AM radio I am not using. From a 67 f100
Thanks for the reply. I have since found a solution for my radio.
-Chris
Id be interested in it.Jaddiethelady wrote:I have an AM radio I am not using. From a 67 f100
1967 F-100 4x4 custom cab.
Busboy wrote:Id be interested in it.Jaddiethelady wrote:I have an AM radio I am not using. From a 67 f100
I have this still as well. It is not in great shape but all the pieces are there. It could use a good cleaning. It will be a task to remove it from the dash, because it will be the first one I have removed. If you are still interested let me know and I will start attempting to take it out SLOWLY .
Thank you, Jade
1967 F100 Shortbed
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
what do you need for it and the bezel
I am honestly not sure what it is worth. Make me an offer? When you say "and the bezel" do you mean the radio bezel? I would give you it as a set no problem.
Thanks!
Thanks!
1967 F100 Shortbed
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
Do you know if the radio works or not?
I do not. I bought it as a parts truck. It was towed to my house.
Thanks, Jade
Thanks, Jade
1967 F100 Shortbed
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
I pm' d you.
got it! Thanks man
1967 F100 Shortbed
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
1978 F250 Crew Cab
1979 Bronco Custom
1988 Ranger
-Jade
