1961-1966 Tachometer gauge and Vacuum Pressure Gauge
1966fordf250
Post by 1966fordf250 »
looking to buy any condition vacuum pressure gauge and tachometer gauge. these were mostly found on the larger trucks like F350 and larger but in some rare instances, they were also found on the F250 and F100s, i think.
Ranchero50
Re: 1961-1966 Tachometer gauge and Vacuum Pressure Gauge
Post by Ranchero50 »
Tachs are mechanical drive so you need to machine the FT dizzy to work in a FE block. I ended up with a tach out of a blue bird bus whichhad similar lettering but was much smaller so I mounted it on the column. Looks dealer installed.
