I have a 1967 F100 352 Manuel steering box
- Godspeed128
I have a 1967 F100 352 Manuel steering box I also have a 71 F100 Doner truck with 390 and power steering can I just move over the power steering to the 67 352 eng and all work? Looks like samee bolt pattern for the pump
Re: I have a 1967 F100 352 Manuel steering box
You have to use everything including the steering column, firewall bracket, steering gear and pitman arm. Engine brackets, pump, pulleys, etc should swap. You may have some issues with wiring harness for turn signals, NSS, etc requiring some rewiring at the column harness connector.
There is a lot of information on this site and others that will answer your questions. Do your research.
1967 F-100 4x4 custom cab.
- Godspeed128
Is it worth all the extra work the doner truck did not come with a steering Column also I already have the motor mounted heck it might not even fit the the headers I’m using take up more space
Unless you can find a Bendix P/S gear box, you'll have to shorten your current steering column. http://www.fordification.com/tech/steering-column.htm
For more conversion info with a steering column http://www.fordification.com/tech/powersteering.htm Headers + power steering has always meant clearance issues especially with an FE. I've had 3 "classic" vehicles in the past 10 years. My truck never had P/S, the others had factory P/S that didn't work. I never fixed them, wasn't worth the extra work and expense.
- Godspeed128
Ok looks like I’m sticking with The manual steering box I just don’t feel like It will be worth it. Im also just trying to make this truck stock just like it was but nice and shiny.
Yeah, you'd have a hard time squeezing a P/S box in there. What headers are those? I've seen a lot of FE header posts on here and those look like some of the best fitting clearances I've seen. Got more photos if how close they are to the frame and crossmembers?
- Godspeed128
Summit Racing
Flowtech Headers 12540FLT
https://www.summitracing.com/parts/big-12540flt
I will get you some more photos tonight,
I like how they look as you can see have not had a chance to run them
- Godspeed128
Some for photos
- Godspeed128
Last one
Thanks for those photos! Looks like you have great clearance all around with those. I'm saving this thread so next time somebody posts about FE headers and clearance problems I can show them yours.
How do you like the flow tech headers? Do you notice any resonance issues at certain speeds or RPM’s.
1967 F100 Styleside Longbed W/352FE. Tremec TKX 5 Speed.
Just loving life.
Just loving life.
