wanted - rear leaf spring shackle bracket
dougself
Post by dougself »
rear leaf spring shackle bracket the one that is 'riveted' to the frame. Passenger side. My bracket is pretty rusty an thinned out. Scares me.
Also would like the frame cross member just in front of the axle. Another victim of rust. These might have to have the rivets drilled out, not sure about the rear leaf spring shackle bracket... see some bolts there.
Are these made after market or do I have to find an old frame to 'steal' them from?
bluef250
Re: wanted - rear leaf spring shackle bracket
Post by bluef250 »
f100 or f250, they are different thicknesses and the year
where are you located?
dougself
Post by dougself »
71 F250 4x4. THank you.
dougself
Post by dougself »
Maryland... I will pay the shipping if you have one... shackle and or cross member.
performancewhite302
Post by performancewhite302 »
If you still need the crossmember, let me know. I'm about 45 minutes from Bel-Air up route 1 in PA. I've got parts from a 1970 F250 available.
