Hello everyone,
First time on here and there is an amazing amount of information. I have a question regarding my truck it’s a 1970 F250 camper special. I’m in the process of restoring it and have a question regarding a keyhole that’s in the rear exterior of the cab behind the passenger door. I can get to it from the inside but there is nothing there. It was wired to something.
Trying to figure out what it is. Debating on keeping it or removing it and plugging the hole.
Thank you
Keyhole behind passenger door.
Re: Keyhole behind passenger door.
Not original, need pictures.
1967 F-100 4x4 custom cab.
With out seeing it , I will guess an add on alarm.
It's up to you to leave it or fix it.
This is a view from the outside inside the cab corner it’s just got two connectors so when the key was open would complete the circut.
- Ranchero50
I'm going with some kind of home brewed ignition defeat.
My first guess would have been an old-school alarm system, but that wouldn't really make a lot of sense being on the passenger side. Either way it's certainly not original, and since it's not currently functional I would personally get rid of it
1971 F100 SWB w/'98 Mustang 302, A4OD, CV swap, 8.8 disc rear, PS PB and soon to be AC
2016 F350 King Ranch Powerstroke 6.7 Crew Cab 4wd daily
2008 F550 Powerstroke 6.4 Service Truck
2007 F250 Powerstroke 6.0 Supercab 4wd dually conversion
2000 E450 Powerstroke 7.3
2017 Explorer 3.5 XLT for the wife
2008 Nissan Rogue for the daughter
2001 S-10 rat rod for the stepson
2017 Yamaha 242 Limited E-series
Thank you everyone for the information. Definitely going to remove it and plug the hole.
