390 motor
tdsmoonchild
390 motor
Post by tdsmoonchild »
Having trouble finding a 390 motor to rebuild around here. If you have one laying around or know where I can look, give me a shout
Mach428
Re: 390 motor
Post by Mach428 »
Have you ever thought about a 390 crate engine? All of the work is done and the cost probably would be less
redstone65
Re: 390 motor
Post by redstone65 »
Mach428 wrote:Have you ever thought about a 390 crate engine? All of the work is done and the cost probably would be less
What's a trusted source for a 390 crate?
Dave
‘65 F-100 (240) Former military truck
‘70 F-100 (360) restoring with my son
Mach428
Re: 390 motor
Post by Mach428 »
Summit has some
redstone65
Re: 390 motor
Interesting. Thanks. Didn’t realize they still carried FE crates.
Dave
urchinhead
Re: 390 motor
Post by urchinhead »
They don’t. Check out the FE Forum.
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
jp2005
Re: 390 motor
Post by jp2005 »
urchinhead wrote:They don’t. Check out the FE Forum.
https://www.summitracing.com/parts/vre-df19/
jp2005
Re: 390 motor
Post by jp2005 »
redstone65 wrote:Interesting. Thanks. Didn’t realize they still carried FE crates.
DuckRyder
Re: 390 motor
Post by DuckRyder »
I don’t know how great those VEGE engines are, there are quite a few folks that will build you a motor though... Brent, and Barry to name 2 then there is I think Brett... Oh and of course Ross...
Do you have a 360 now? because if so you only need a 390 rotating assy... or a 410 rotating assy or a 445 rotating assy... :evil:
