Questions regarding Voltage Gauge & Fuse Box Wiring
crazzmc
Post by crazzmc »
Hi guys,
Ripped apart all my wiring harnesses and re-did everything from the engine bay cause it was awful. My truck starts today which I was happy about, but I really hate that old nasty Fuse Box sitting there. I tried looking at diagrams but I had spliced in wires in the fuses coming directly from battery and it was a little ugly and messy. I was wondering if anyone has a better diagram of the fuse box. The one on the website are all split based on different connections and its a little confusing to trace because not all of my wire colors match up. I was wondering if you guys can tell me what components need a Hot signal directly from battery into the fuse box (some of the writing i saw was like wipers, cargo light, dome, heater, etc) and which ones need a signal from the ACC. I want to completely get rid of the box, but I just am not sure what to do right now, I do have a new fuse box that I bought that will be powering my Radio, Amp, Speakers, Lock System.
Also my Voltage Gauge would always fluctuate. I ended up tracing the wire I spliced into and it came directly from the battery. My battery constantly reads 14.65 Volts so i don't think its a problem anywhere there and my Voltage Regulator seems relatively new. I have an aftermarket Speed Hut Voltage Gauge. Is there a specific wire I should draw the signal from that's better?
Almost done tidying up the wires so I'll post the before and after pics of the engine bay and the fuse box once its all wired up! Thanks for all the help pretty new to electrical!
-Crazz
Figuring out this whole restoring process with my 68' F100.
Re: Questions regarding Voltage Gauge & Fuse Box Wiring
The best $18.00 I ever spent on the truck, (even though what you've pulled out from under the hood wouldn't apply anymore). :wink:
I kept mine rolled up and stored in the glovebox for those times when the truck decided to quit running on the open road.
https://www.ebay.com/itm/1968-68-Ford-F ... 546d25cf21
Another consideration https://youtu.be/s7npq2HVszM
