Anodized Aluminum steering wheel horn ring
idahiboy
Post by idahiboy »
I was polishing my horn ring and there were some deep pits that needed more aggressive sanding.... I "wore through" a layer in a few spots and it's a different color (brighter silver) with a super thin "copper like" layer.
So that copper layer is the "anodized"? Do I need to sand through all of that or did I ruin the metal? There was really no way to remove these small pin hole pits without the going that deep
For some reason I can't post photos right now as trying to attach but saying "too large"
I have read a few of the other threads on "how to" with aluminum but didn't see this "copper colored layer" discussed
Thanks for any advice
1968 F250 FE 390
idahiboy
Re: Anodized Aluminum steering wheel horn ring
Post by idahiboy »
1968 F250 FE 390
CH3NO2
Post by CH3NO2 »
Horn rings are chrome plated. Every thing that gets chrome plated is plated in copper first to help the chromium stick to the part. So if you are down to the copper it will have to be replated.
idahiboy
Post by idahiboy »
CH3NO2 wrote:Horn rings are chrome plated. Every thing that gets chrome plated is plated in copper first to help the chromium stick to the part. So if you are down to the copper it will have to be replated.
Thanks for the response..... It was not "magnetic" in any way when tested so I thought it wasn't chrome..... Is it aluminum below the copper? Can I just sand through the copper everywhere and then buff and clear coat?
1968 F250 FE 390
I believe they are cast aluminum. New repros are only $100 and there are several used ones on Ebay now for under $40. So what the heck, I'd go for it.
