window regulators
window regulators
Looking for a pair, they don't need to actually function. I'm putting power windows in and am going to modify the regulators with 2 microswitches each for up and down. So it will still look like manual windows, but all you do is move the window handle a little each way to move the window. I can get something like this pre-made but I think I can make them for cheaper.
Re: window regulators
Have you seen this? http://fordification.com/forum/viewtopic.php?t=72410
Yea I saw that but I picked up some after market power window mechanisms for flat windows that mount centered on the window.
Be sure and show us what you do and how you did it. Power windows are a hot topic here.
will do, these were is the discount bin at the Summit up in Ohio when I was there a few years ago, they work, just no switches
- Ron_Hall
Zorm, did you ever find the regulators?Zorm wrote:Looking for a pair, they don't need to actually function. I'm putting power windows in and am going to modify the regulators with 2 microswitches each for up and down. So it will still look like manual windows, but all you do is move the window handle a little each way to move the window. I can get something like this pre-made but I think I can make them for cheaper.
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
not yet, been sidetracked. Finishing up a home project then back to the truck. I am also assuming the regulators from a 73-76? would work also, bolt up the same?
- jzjames
This would be good to know - I’ll be needing to do mine, down the line.Zorm wrote: assuming the regulators from a 73-76? would work also, bolt up the same?
- Ron_Hall
Here is some pics if you want to look at them.Zorm wrote:not yet, been sidetracked. Finishing up a home project then back to the truck. I am also assuming the regulators from a 73-76? would work also, bolt up the same?
Ron
One owner...
One owner...
Ron_Hall, I would just be using the handle/toothed part. Take that long arm off, mount a two cams on the gear to engage two different micro switches, one up, one down. I'm getting some sealed relay packs from a member on the IFSJA forum to help with window power. Thanks for the pics though.
- FLASH 1
73-79 are not the same as the 67's or 68/72's and even all 73/79's are not the same. some trucks the regulators where bolted in < 3 bolts > and others where riveted in the door
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
