Factory Paint Type for 67 F100
dstuart
Post by dstuart »
What kind of paint was used at the factory on 67 F100s? Acrylic enamel? Laquer? Urethane? If I’m going to paint the truck and use the original color (Rangoon Red) should the same type paint be used? Or has paint improved enough in 50 years to justify using a better type paint? Thanks for any insight!
390FE1972
Re: Factory Paint Type for 67 F100
Post by 390FE1972 »
I'm not sure about new paints vs. old paints and which one is better, but I believe the paint used on our trucks was a single stage urethane paint. My original paint looks pretty good considering it has been on there for 47 years.
Regards :thup:
sparky72
Post by sparky72 »
IMO, if you’re going whole-hog with a repaint, there’s no reason not to get the best paint you can afford. Single stage paint is nice and all, but paint technology has advanced by leaps and bounds since our trucks were made.
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
91Bear
Post by 91Bear »
dstuart wrote:What kind of paint was used at the factory on 67 F100s? Acrylic enamel? Laquer? Urethane? If I’m going to paint the truck and use the original color (Rangoon Red) should the same type paint be used? Or has paint improved enough in 50 years to justify using a better type paint? Thanks for any insight!
I used single stage Sikkens paint (New LIme) and have gotten many compliments on it.
Post by basketcase0302 »
="dstuart"What kind of paint was used at the factory on 67 F100s? Acrylic enamel? Laquer? Urethane? If I’m going to paint the truck and use the original color (Rangoon Red) should the same type paint be used? Or has paint improved enough in 50 years to justify using a better type paint? Thanks for any insight!
You'll probably find the answer to your question here in the Dealers Info: :wink:
http://www.fordification.com/library/in ... category/1
