unfactory highboy
4x4 & Off-road Forum Archives
Moderator: Doug Comer
ak-1970-360
unfactory highboy
Post by ak-1970-360 »
can i convert my 70 f100 4x4 to a hightboy. I dont need the clearance i just like the look of the big 4x4s. How hard would this converstions be and what do i need?
heep70
re: unfactory highboy
Post by heep70 »
Add a suspension lift kit. I believe they come in 2" & 4" lifts. Or you can have a spring shop custom build you lift. Call some 4x shops.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
ak-1970-360
what would look more stock the 2'' or 4.
heep70
Post by heep70 »
I am not sure how much taller a "highboy" is to an F100 4x4. I would go with the 4". Did you do any calling around yet to see what is available? 4 wheel parts wholesalers has lots of inventory.
http://www.4wheelparts.com/4wp/index.asp
Greg
ak-1970-360
ya i would have prolly chosen the 4''. bigger is better
i also need some 16'' 5 lug pre-97 ford rims. my parents gave me a set of brand new tires but i need 16'' rims for them so if ya know of anybody that has a set of them sittin around send them my way.
thanks
magnethead
Re: re: unfactory highboy
Post by magnethead »
ak-1970-360 wrote:bigger is better
3 Words: Center Of Gravity
ak-1970-360
id like to run 35 or 37 inch tires so shes goin up. :twisted: :rock:
ak-1970-360
i looked at 4 wheel parts and they didnt have any lift kits for 67-72 Fords. the only ones i've been able to find are from rough country.
dotcentral
Post by dotcentral »
ak-1970-360 wrote:i looked at 4 wheel parts and they didnt have any lift kits for 67-72 Fords. the only ones i've been able to find are from rough country.
Would a 73 to 77-1/2 F100 lift work on a 67 to 72? Seems like they're similar enough to where it might.
heep70
Post by heep70 »
That holds true with the F250s. I bet its the same with the F100s.
Greg
ak-1970-360
i hope its the same and i will look at skyjacker.
thanks
ak-1970-360
well that took all of 2 min. skyjacker sell a 2'' 4'' and a 9'' lift for 65-79 f100s.
ak-1970-360
thats what i thought. it just kind of suprised me that all the lifts are the same for 65-79. at least thats what their advertising them for.
willowbilly3
Post by willowbilly3 »
Just make sure you put on a new track bar and pitman arm to go with the lift or it will be a bump steering death trap.
And watch out for that big hole just to the left when you dive off into Jim Creek, we pull someone out of there every time we go out. I've seen new Toyotas in over the top of the hood. :lol: :lol:
460 crew
Post by 460 crew »
Skyjacker has a 2,4,6, and 9 <--- :D inch lifts for your f100 70-72 you'd be big and still have a smoother ride with the coils plus more travel. Only lifts for the leaf sprung highboy is a 2 and 4in.You could fit 40-44in tires in there but with the f100 axles I'd recommend nothing bigger than a 35-37in on stock running gear. if you have any ?'s I have a skyjacker master catalog............... oops didnt see some of the above posts :eek:
