Exploded Diagram, 4x2, 4 Speed, Power Steering Column
urchinhead
Post by urchinhead »
I do not see the diagram in the technical section for 4 Speed Trucks, only the 4x4.
Are one of the diagrams close enough to use for my 1970 4-Speed F100, 4x2?
I have a parts pile 1974 column and 1970 or earlier steering wheel from an earlier power steering conversion and I want to make sure that I have the correct parts to match up. I may keep the lower bearing style from '74 and utilize an aftermarket roller bearing, but just want to make sense of everything I have first.
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
390FE1972
Re: Exploded Diagram, 4x2, 4 Speed, Power Steering Column
Post by 390FE1972 »
You may have already seen these, and I'm not sure it will help you with your answer but here they are just in case:
http://www.fordification.com/partnos/st ... column.htm
http://fordification.com/tech/steering-column.htm
Regards :thup:
urchinhead
390FE1972 wrote:You may have already seen these, and I'm not sure it will help you with your answer but here they are just in case:
Regards :thup:
I have seen the diagrams - which may be all that is out there - but I did not come across the article on chopping down the column, so thanks!
390FE1972
Post by 390FE1972 »
This company is a good source of steering column parts, they used to do rebuilds. They might be a good place for asking questions on your rebuild.
https://www.carolina-classics.com/36-steering-column
Let us know what you find out.
Regards :thup:
urchinhead
Thanks 390FE1972. I looked up that company when I first bought my truck and started buying parts. I have almost everything at this point, so I will post what I figure out.
