67 F100 Missing Emergency flasher switch
simknot
Post by simknot »
IF the emergency flasher switch is missing will this disable the brake lights? Because it is missing
I have a new brake switch and i can jump from the out going side of the switch to the brown brake wire and the lights work. But that feeds back to the dash lights and lights them up too. Is there a way jumper the switch harness or do i have more problems than that? Thanks for any help you can offer.
jor
re: 67 F100 Missing Emergency flasher switch
Post by jor »
No. The brakes will function without the E-flasher in place.
jor
simknot
Post by simknot »
ok. i'll start digging for the problem wire(s). I also did pick up a switch on ebay today thanks for the info.
