Ranger Bed Emblem Location
Blue_Streak
Post by Blue_Streak »
Hi All;
So with all this stuff going on with the Corona Virus going on and the world going to hell in a handbasket , I find myself initially working from home and maybe a potential layoff depending on how long this economy tanks. I've decided that I have a bit of time to get back to work on the rebuild.
I am changing my 1967 base cab into a Ranger model with a lot of the accompanying Ranger trim although not always year correct to my '67. Anyhow , since my base didn't have the Ranger emblem on the bed I am looking to see if anyone might have the correct pin hole locations for each side so that I can drill the proper holes. Maybe dimensions from the upper bump seam and say the tail light extender seam. I did a search and nothing came up. I did find a schematic for the location of the car door mirrors in the tech section as my doors had the western mirrors.
Thanks in advance
beejaytx225
Re: Ranger Bed Emblem Location
Post by beejaytx225 »
Maybe this will help? I'll measure it when the rain stops.
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Central Texas
Blue_Streak
Yes. Thank you for the pic. That does help a little bit. What's that like an 1" , 1.25" from each seam?
beejaytx225
Looks to be about 1.75" from rear body line.
And about 1.5" from lower body line
360 w/C6
Peacock Blue
Central Texas
beejaytx225
If you need the measurements for the holes that need drilled in the bed let me know. :thup:
360 w/C6
Peacock Blue
Central Texas
Blue_Streak
That's awesome. Thanks so much. I really appreciate it.
And if you mean the actual hole locations for each side , that would be perfect.
If you mean where the pins are on the emblem , I have the re-popped emblems so I can hopefully, correctly do the math.
