Posting an update!
- beejaytx225
Re: Posting an update!
One thing that bothers me a bit is this mounting point for the passenger side I beam.
Do you see how it angles back a bit? I don't know if that is normal or if something hit it in the past and bent it back. I can't find another truck to compare it to.You do not have the required permissions to view the files attached to this post.
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
Nope, not normal. Mine were straight and vertical. A few photos of mine, before and blasting my frame are toward the bottom of the first page in my build thread in my signature. Here's a couple of shots I just went out in the garage and took.
- beejaytx225
Oh boy... Thats kinda a bummer. But! I do appreciate the help sargentrs! I guess I'll dive in and see what my options are
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- beejaytx225
Looks like I'm gonna have to pull the bent bracket off and either straighten it or replace from a donor truck. After installing new I-beam pivot bushings and radius arm bushings the driver's side beam no longer clears the bracket. Diving into some heavy metal tweaking
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
Don't know how much of a restoration you are planning, or if you are willing to use fabricated aftermarket parts. If you are you might want to check this out:
https://autofab.com/i-22828666-65-79-f- ... pivot.html
My truck is a 4x4 and I haven't used them. Little expensive, but it's probably stronger than the original and its available if you can't find used.
I happened upon their beam pivots for the I-beam Rangers when searching for something else. I've got a stalled 86 Ranger project truck and one of its beam pivots is worn due to loose pivot bolt. When I found them I saved the link and will be ordering a set for the Ranger if I ever resume that project.
- beejaytx225
That is absolutely outstanding!!! Thank you so much JoshT! I was having no luck finding an aftermarket bracket till now
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- beejaytx225
After a thorough review of their website and the Google reviews....part is ordered will post pics and updates when I get it
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
Please do! I know it isn't the same part I need, but still interested in seeing what you receive and think about it.
Like I said price is a little high IMO, but they are the only ones I've found offering it. If word on the interwebz can be believed, imagine you'll be getting what you paid for.
- jzjames
Yep. That was a life saver.
- beejaytx225
Received the bracket from AutoFab today. Have to say it's a pretty solid piece. Good welds, thick metal.
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- beejaytx225
Got the new bracket cleaned, primed and painted. Will be removing the bent bracket tomorrow
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
Can't wait to see how it works out! Good luck!
- beejaytx225
Got the new AutoFab bracket mounted. Holes lined up "okay" I'll probably end up welding it to the frame. But super stoked that I can finally get the front axles back on
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- popeyes71
Those brackets look great! Looks like assembly of the front end is in the near future.
I can see progress with every update that you create on this thread. It seems like the modification process is going well on your end and I can't wait to see how it goes.
