Rear cab mount bolts
- beejaytx225
This is a picture of my driver's side rear cab mount. The passenger side looks the same. Isn't there supposed to be a nut on these studs?
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Central Texas
Past Ford's: 1994 Ranger, 2008 Ranger, 1991 Ranger, 1985 Mustang, 1968 SB Custom Cab F100, 1998 Explorer.
Current Ford's: 2011 Ranger, 2006 Expedition, and of course Bethany
360 w/C6
Peacock Blue
Central Texas
Re: Rear cab mount bolts
I believe that style of retainer is threaded going up into the bushing.
And a royal pain to break loose with 50 years of rust welding it together. I used vice grips on the outer edge of the lower flange to hold a backup while working the bolt from inside the cab. Spray liberally with PB Blaster or equivalent and let soak. Repeat as necessary. Be gentle and work the bolt a little at a time back and forth. Once the bolt is out, spray inside and let soak. The top and bottom pieces have interference fit tubes and a little emboss that "click" together. They rust together like they're welded but with patience and tenacity they'll come apart.
- beejaytx225
Thank y'all, it had me concerned . Good to go
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- CH3NO2
My . There is no equivalent to PB Blaster !!sargentrs wrote: And a royal pain to break loose with 50 years of rust welding it together. I used vice grips on the outer edge of the lower flange to hold a backup while working the bolt from inside the cab. Spray liberally with PB Blaster or equivalent and let soak. Repeat as necessary. Be gentle and work the bolt a little at a time back and forth. Once the bolt is out, spray inside and let soak. The top and bottom pieces have interference fit tubes and a little emboss that "click" together. They rust together like they're welded but with patience and tenacity they'll come apart.
Much better than WD40. Here's an interesting comparison from awhile back.
http://www.fordification.com/forum/view ... hp?t=44934
- beejaytx225
That's actually a pretty neat study. Never would have thought of the home brew! Cool stuff
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
- jzjames
This thread has answered the question I have had for a long time. — Why doesnt my rear cab mounts have any nuts on the bolts? ive often thought I need to get down there and put some on
- beejaytx225
I'm happy my inquisitive nature has helped someone
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
One of mine was toast. I used one of the others as a pattern. Fortunately I have access to a laser and band saw at work. Cut 2 washers and 2 pipes, diffrrent sizes. Using long bolts, nuts and lock washers to mount.
Randy: Just spitballin' here.....If you weld a deep nut to the two big washers that will be underneath, if/when you have to take things apart at a later date, you can stick a deep socket on the nut, use an impact from the bottom, and have someone inside with a wrench holding the head of the bolt.......
James
James
You are onto something for disassembly. There is a video or two of where they make a "puller" to pop these apart. VERY good idea as it beats a sawzall by a country mile! Use the threading to your advantage.
Good idea! Thanks for the tip!jamesdfo wrote:Randy: Just spitballin' here.....If you weld a deep nut to the two big washers that will be underneath, if/when you have to take things apart at a later date, you can stick a deep socket on the nut, use an impact from the bottom, and have someone inside with a wrench holding the head of the bolt.......
James
- jzjames
A useful pc. of information I came across on FTE. (They let me back on their site, I guess bygones be bygones)
This must be for the other type of body mounts/bushings.
https://www.prothanesuspensionparts.com ... e/6110.pdf
