1 wire vs 3 wire
BigAl47
1 wire vs 3 wire
Post by BigAl47 »
Want to upgrade my alternator to 100 amp but I’m having a problem finding with the 3 wire oem connection. Is it a problem using a one wire alternator if so will the amp gauge still work? Any other problems
Thanks :fr:
390FE1972
Re: 1 wire vs 3 wire
Post by 390FE1972 »
Here is an interesting youtube by Auto Restomod, where they install a 100AMP one wire alternator on a 1972 F100:
https://youtu.be/qA8p2EThGXc
Hope this helps! :thup:
HDxLoki
Post by HDxLoki »
I'm currently in the middle of my 390 rebuild. When it come times to the charging system I plan on throwing in a Ford 3G Alt from a late 90's Mustang with a 3.8L. Mostly because you can pick one up at just about any autoparts store. Plus that 130 amps is more than enough to power my Spal fans and electronic ignition.
Here's a few links that helped me make up my mind:
https://www.hotrod.com/articles/install ... der-fords/
http://www.fordification.com/forum/view ... =8&t=82359
1972 F250 Ranger XLT Camper Special 390ci Bought Brand new in 1972 and passed down from my Grandpa after he passed
RIP Paul & Von
A good article on 1 wire vs 3 wire alternators.
http://www.madelectrical.com/electrical ... wire.shtml
BigAl47
Post by BigAl47 »
Can you still use your oem alternator bracket for the mustang alternator :fr:
Thanks
