Heater issues
Blueford1
Heater issues
Post by Blueford1 »
Hello All,
The heater in my f100 is always blowing. It always starts to heat up after the engine is warm. I installed a new thermostat and nothing has changed. Any ideas?
Thanks.
1970 F100/302 5.0/4 speed/ Ford9inch 3.70
390FE1972
Re: Heater issues
Post by 390FE1972 »
I would check the in-line valve in your heater hose first, they often get rusty and won't open and close properly. Here is a thread that talks about the similar problem to yours: https://www.fordification.com/forum/vie ... =6&t=96179
Let us know if it is working or not, I would suggest that you pull it and make sure it looks like it is working properly.
Regards :thup:
Blueford1
Re: Heater issues
Post by Blueford1 »
You were right! The heater valve was stuck open.
Thanks so much.
390FE1972
Re: Heater issues
Post by 390FE1972 »
Glad to hear you got it fixed! :woohoo:
Blueford1
Re: Heater issues
Post by Blueford1 »
Ok. So I thought that replacing the in-line valve and the heater hose worked, but it did not. The heat just blows when I'm actively driving down the road. When I stop at a light there is no heat. Any ideas?
Thanks.
DisneysPatB
Re: Heater issues
Post by DisneysPatB »
https://www.dennis-carpenter.com/trucks ... -fresh-air.
The "foam" seals deteriorate with time. This is what you need to fix that. I am doing this in mine right now.
