What part is this?
Old+Blue
What part is this?
Post by Old+Blue »
On my new-to-me old truck, I was working on the brakes and notice this hanging down, underneath the drive shaft.
What is it?
Should I remove it?
Thanks for any help.
1967 F100 352 Auto LWB 2WD Camper Special
pcmdub
Re: What part is this?
Post by pcmdub »
Guessing without a wider pic. Did someone remove the 2nd gas tank? My under-cab tank has brackets like that.
Old+Blue
Post by Old+Blue »
pcmdub wrote:Guessing without a wider pic. Did someone remove the 2nd gas tank? My under-cab tank has brackets like that.
Oh! That could be it! It does have 2 filler caps but just 1 tank....
Thanks!
yellercat
Post by yellercat »
That is a bracket for the auxillary gas tank SHIELD.
Just replaced mine and the item circled doesn't actually hold the tank, but the shield that goes underneath the tank.
BTW , was missing a smaller bracket that attached to the trans crossmember on mine that looks like a small angle bracket; you don't happen to have that one do you ?? :D
1970 F100 302 C-4 factory air
