Pitman arm reassembly 72 F100 manual steering
pickly
Post by pickly »
Anyone have advice on the order in reassembly for the pitman arm, gear box and rag joint for a 72 F100? My bearings went out on my manual steering gear box so I rebuilt it and replaced the rag joint. I have the rag joint and gear box reinstalled but I 'm having problems getting the pitman arm back on the gear box output shaft. Thanks!
1972 F-100 | 390
Re: Pitman arm reassembly 72 F100 manual steering
Post by basketcase0302 »
="pickly"Anyone have advice on the order in reassembly for the pitman arm, gear box and rag joint for a 72 F100? My bearings went out on my manual steering gear box so I rebuilt it and replaced the rag joint. I have the rag joint and gear box reinstalled but I 'm having problems getting the pitman arm back on the gear box output shaft. Thanks!
IT IS "KEYED" (HAS A WIDE SPLINE THAT HAS TO LINE UP) THAT ONLYU ALLOWS IT TO SLIDE ONTO THE SECTOR SHAFT IN ONE POSITION.
You might have to rotate/turn the steering wheel to get it to line up to the front end's current position. :thup:
