1969 Ford F250 Crew Cab full custom build
IML726
Post by IML726 »
I have a 1969 Ford F250 Crew Cab that I bought in 2017. The previous owner said it was a utility vehicle for the railroad in AZ. It came with a SBF 302 and a 4 speed manual transmission. The original plan was for a modern upgrades and keep as a daily driver. That plan morphed into a full custom build. It now sits on a new bagged/body drop chassis from Acme Chassis Factory of Houston, TX. It has a 2019 Gen 3 Coyote with a 10R80 transmission. The brakes have been upgraded to Wilwood 6 piston disc brakes. The wheels are 24x9 and 24x15. It has complete stainless steel hardlines for the brakes, fuel, and air suspension. It also has Ultimate Headers and a custom 3" stainless steel exhaust with FlowMaster mufflers.
Below is a link to all the photos of the truck since I bought it.
https://photos.app.goo.gl/dgBmvKtFn5WFNAue8
Re: 1969 Ford F250 on bagged/body dropped chassis
Wow, a lot of work to this point. Doesn't look much like a daily anymore though.
IML726
Post by IML726 »
Lol, nope. Now I have to buy another truck to be the daily driver and tow this truck.
Re: 1969 Ford F250 Crew Cab on bagged/body dropped chassis
Was there supposed to be a link here Paul?
That'd be a bad to the bone ride!
IML726
Post by IML726 »
Here is the link to the photos
jimmy828
Post by jimmy828 »
All i can say is VERY NICE build. Hope to see more post. :thup: :thup:
IML726
Post by IML726 »
Thank you. I'll keep adding to my album as it progresses, while I learn the album/upload process here
IML726
Post by IML726 »
Pictures of the frame:
IML726
Post by IML726 »
Body was sand blasted and epoxy primered.
IML726
Post by IML726 »
Cab Mounted to the frame
Stop it man LOL! :lol:
I'm drooling all over my keyboard! :eek:
I've got Coyote on my wishlist too, (but for an airboat application to smoke a few chebbies that so many airboaters run down here). :evil:
Promise us a video of it smoking the tires please! :pray:
Awesome one of a kind frame off build for sure and congrats on all the hard work and the progress so far. :thup:
What kind of control will be on the throttle body?
And is that a 56' Ispy in the background of the one pic?
My older brother up in the Atlanta area built a frame off 56' years ago.
IML726
Post by IML726 »
Thank you. It's at the sheet metal shop right now. The shop owner has a few Fords in his possession. I'm not sure what year the one in the background is.
For now, the plan is for the engine to be mostly stock except for a BOSS intake manifold and replacing the cams.
There is a ton of sheet metal work to be done. Starting work on the floor pan and tunnel, then moving on to firewall.
IML726
Post by IML726 »
IML726
Post by IML726 »
Current status. First time with the front end on since the truck was taken apart. Waiting on hood hinges to check clearance for the intake manifold. The hood will need some work to clear the manifold.
Firewall is being finished up. Placed a Kugel Komponents remote master cylinder behind the dash bc there wasn't enough space due to the engine sitting higher. We'll also use Wilwood remote brake fluid reservoir. Waiting on the Restomodair Haymaker to determine fitment behind the dash.
Lots of sheet metal work left to do.
Driveline Tunnel
Trique Mfg Easy Latch
